This variable is undefined
SOLVED
AK_9784236
Visitor
After increasing array size of t the variables getting undefined. Help me please. Im very new to the MathCAD. Error occurs on MatchCAD15
 If n<= 10 then all works fine. But i need it to be 25
1 ACCEPTED SOLUTION
Re: This variable is undefined
You may consider changing the value of E0 to avoid the division by zero!
4 REPLIES 4
Attach pls Mathcad-sheet!
I attached two sheets, the one that is working, and the one that is not.
Tags (1)
Thank you!
Tags (1)
