This variable must be a function but has the form unitless
Participant
Re: This variable must be a function but has the form unitless
Don't post just pictures - attach you worksheets.
You are using the wrong syntax for odesolve - look it up in the help.
And please close your other open threads here in the forum.
can you explain more detail?
You should write k multiplied by....and not k(
