Toolbox: Solving Ordinary Differential Equations symbolically
SOLVED
Sapphire III
As of now it is possible to solve Ordinary Differential Equations (ODE) symbolically in Mathcad, as long as:
-the ODE is linear (does not involve powers or products of the sought function or its derivatives), and
-the coefficients of the derivatives are constant (do not depend on the independent variable).
This means you can solve:
The result is:
Check out the attachments for further information.
The solver "LODEsolve" (reference file for insertion in your sheet) and an example usage file "LM_20200923_LODEsolve" are attached.
If you're using:
- Mathcad 11, use LODEsolve.mcd (it will NOT work in Mathcad 15) and check out example file LM_20200923_LODEsolve.mcd.
- Mathcad 15 use LODEsolve.xmcd  and check out example file LM_20200923_LODEsolve.xmcd.
If you're using (any version of) mathcad Prime: Install Mathcad 15 and use that before you can benefit.
Comments, kudos and suggestions for improvement are welcome.
(Thank you @Werner_E for conversion to and checking of Mathcad 15 functionality.)
Tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: Toolbox: Solving Ordinary Differential Equations symbolically
Found an error in the symbolic processing of the Mathcad 15 edition of LODEsolve, as a result of which it wouldn't solve sets of ODEs.
That is corrected now.
7 REPLIES 7
Highlighted
Re: Solving Ordinary Differential Equations symbolically
Dear Luc & Werner thank you for these nice worksheets and for the continuous support both of you provide to the Collaboratory. I have learned so much from you both. Best regards, Filip
Highlighted
Update:
It is now also possible to solve sets of Linear Ordinary Differential Equations.
An example:
See attached, and enjoy.
Highlighted
Congratulations! So you finally succeeded to make it work in MC14/15, too? I had not taken a closer look yet - what was the problem with the earlier attempts?
Highlighted
Things that Mathcad 11 can do, but 15 won't.
See the other thread.
Highlighted
Highlighted
Dear Luc, thanks to a friend I can use MC11. However I find something strange when loading your worksheet everything seems to work fine with exception of example 1, 17 and 18 where I get the message "No symbolic result was found". Do you have any idea why this happens? As you did not see the problem I have added a print screen
Thanks for your help!
Highlighted
Just encountered this:
It also happens when a gets an index subscript. It does NOT happen when y, t or fixed get a subscript. I have no clue (yet) what causes it 😲.
And it does not appear to happen in Mathcad 15...😮
