Tri-diagonal Matrix Algorithm (TDMA)
festivus-disabl
Is there anybody who has coded the Tri-Diagonal Matrix Algorithm (TDMA or Thomas algorithm) in mathcad and would be willing to share it?
jbanks
(To:festivus-disabl)
Dear Festivus, I had seen your message today for the first time since
I am migrating to Mathcad Prime 7.0. Attached is the TDMA that I had
developed in 1985 (The Fortran source code which I had used as
basis is my TDMA and it states the date).
I have successfully used TDMA in two distinct heat transfer simulations
in a transient interior ballistics solution of a RLPG (Regenerative Liquid
Propulsion Gun and also in a steady state thermal liner heat transfer in
F100 thermal liner.
It is my pleasure to freely share my IR&D (Independent Research
and Development) algorithms.
Attached are the "Algorithm derivation along with the Fortran solution
implementation" in one PDF file. The second file is my implementation
of TDMA imported into Mathcad Prime v7.0 from the Mathcad v15 original
file.
I hope that these TDMA files will serve well our PTC Community.
Sincerely
Julio C. Banks
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
