Turbo Code encoder in Mathcad
ptc-5051640
Can anyone guide me or provide code to create turbo code encoder in mathcad.
11 REPLIES 11
MikeArmstrong
(To:ptc-5051640)
Can you give us something to work with. You cannot expect collabs to use there own time without providing something yourself.
Mike
Just a simple encoder of turbo code encoding random number.
Simple???
http://dtlweb.au.af.mil/webclient/DeliveryManager?pid=37482
Author seems to have used Matlab for modelling.
There seem to be some modules for VisSim to do the task
http://www.adeptscience.de/visualsolutions/de/comm_turbocodes.html
http://www.adeptscience.se/products/mathsim/vissim/turbocodes.html
http://www.adeptscience.co.uk/products/mathsim/vissim/vs4mcad.html
Anyone know if it will still work with current Mathcad versions?
You will have to have a lot of luck if anybody is able and willing to share a full implementation in Mathcad you can adapt to your needs.
Thanks for help. But I only requre mathcad mathematical modelling.
Werner,
This link does not work.
...Anyone know if it will still work with current Mathcad versions?...
Quote from discussion "What versions of Mathcad does VisSim work with?" (http://www.vissim.com/forums/what_versions_mathcad_does_vissim_work#comments😞
"VisSim works with Mathcad versions to 14. There are some issues with the latest Mathcad 15 that are under examination. Note that you can translate most Mathcad worksheets directly to VisSim which will give you a speedup in execution on the order of 1000x."
Werner,
There is a any chance to attach this PDF document? I still can not open this page.
Thanks.
VladimirN. wrote:
Werner,
Thanks.
Here you are.
Could it be that US military site is not accessible from Russian IP???
Thanks!
P.S. By the way, you can use the archiver before attaching file.
You're right - would have been half the size.
