Unable to type a string into a variable definition
ptc-2718280
1-Newbie
Hi there
Can anyone help with the above problem? It appears either a setting has been toggled off or the shortcut keys have been altered.
Either way, I am now unable to type a " to type any string into any of my Mathcad worksheets
Any advice welcome.
1 ACCEPTED SOLUTION
MikeArmstrong
(To:ptc-2718280)
I don't see an issue.
Mike
6 REPLIES 6
MikeArmstrong
(To:ptc-2718280)
What version of Mathcad are you using and can you provide an example worksheet?
Mike
Thanks for your quick reply Mike.
I am using version 15. I have attached a blank copy of the offending sheet.
MikeArmstrong
(To:ptc-2718280)
Mike
Thanks again Mike.
I have Mathcad open twice, i.e. in two different instances and not just two different windows. It appears that the problem only affects the worksheet in the second instance of Mathcad. I still can't type a quotation mark in the second instance.
Thanks for your help anyway, I will open the worksheet with my working instance of Mathcad!
MikeArmstrong
(To:ptc-2718280)
I have just replicated your method and defined a string without a problem in both worksheets.
What version of M15 are you running?
Mike
Andrew Macintyre wrote:
...in the second instance of Mathcad...
And how many licenses of Mathcad you use (in a license file in "Summary Table" there is a field "Qty" ("Quantity"))?
