Unit display / control
dcreces-disable
Is there a way to have Mathcad 2001 perform calculations in units I specify? For example, temperature in deg C instead of K? I can define degC:K but the answer is always reported as K, even if C is what I need. Time is the same, I often want results in hours but trying to convert I still get s as the unit. Or energy units, kJ/kgK get reported as Sv in the answer even though the body of the calc has units entered as shown.
Can you help please? The only thing I can do is perform the calculation without units but then I run the risk of missing a conversion...
TIA,
Dan
Like so:
Richard
See the tip # 64
http://twt.mpei.ac.ru/ochkov/Units/advice64.htm
from the book "Tips for Mathcad Users"
and http://www.wsp.ru
Valery Ochkov
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
