I'm trying to create a calc where the answer is a design factor. The calc works fine when just using numbers, but when I try to use a value from earlier in the sheet I get the 'units are not compatible message'. Would appreciate any help on this, thanks.
1.4 is a dimensionless quantity
a similar question
This is the biiiiiiig old problem of "designed equations" from diverse textbooks or scriptums for example. A really big Problem
You have to check out first, which dimension the variable Df must have.
The parameter 1.4 must have the same unit like Df.
If 0.6 is a uitless factor then ok, but the 50 must have the unit of Unit(Tdt)*Unit(Df)²
True. But, in my experience, design factors are usually dimensionless.
Alan
Thanks everyone, I've got it working now. All the replies are appreciated 🙂
Alan
Many of these "design factors" are unit conversions
@Fred_Kohlhepp wrote:
Alan
Yes, though these are usually supplied as single numbers rather than expressions that require evaluating, are they not?
Alan
