Units are not compatible
SOLVED
Guest
I'm trying to create a calc where the answer is a design factor. The calc works fine when just using numbers, but when I try to use a value from earlier in the sheet I get the 'units are not compatible message'. Would appreciate any help on this, thanks.
1 ACCEPTED SOLUTION
Re: Units are not compatible
You need to give the 50 units also:
Alan
8 REPLIES 8
1.4 is a dimensionless quantity
a similar question
Alan
This is the biiiiiiig old problem of "designed equations" from diverse textbooks or scriptums for example. A really big Problem
You have to check out first, which dimension the variable Df must have.
The parameter 1.4 must have the same unit like Df.
If 0.6 is a uitless factor then ok, but the 50 must have the unit of Unit(Tdt)*Unit(Df)²
Volker
If you combine the two solutions: first and second, you can find a way to formalize the empirical expressions
Tags (1)
True.  But, in my experience, design factors are usually dimensionless.
Alan
Thanks everyone, I've got it working now. All the replies are appreciated 🙂
Alan
Many of these "design factors" are unit conversions
@Fred_Kohlhepp wrote:
Alan
Yes, though these are usually supplied as single numbers rather than expressions that require evaluating, are they not?
Alan
