Use Input Tables for data
Newbie
When worksheets are to be accessed by numbers of students in large classes and from remote locations, the use of the Input Table is strongly suggested. This feature places the data to be utilized by the student in a single document.
The previous use of READPRN required that the *.prn data file was in the working directory. Otherwise you had to assign the remote file to a filename... I can no longer remember how that went.
Use Insert/Component/Input Table to get the table. You can then copy and paste to get additional copies. Name each array for the data it contains.
The input tables can be parked across the right margin to reduce the clutter in the finished student report.
Physics: Common Sense made obscure by Mathematics
The other advantage to Input Tables, is that students can scroll through the data used, and also edit it if they want.
Mona
