Use of user defined functions in double definite integrals as limits of integration
ptc-4229833
1-Newbie
I am trying to create a general function (function to determine centroid of a curve) that I can then use throughout my calculation sheet. I therefore need to pass a function for a curve into my general function, which will be used in a limit of integration placeholder.
I have attached an example. I am able to place my function directly into the integral placeholder to act as an integration limit, but I cannot pass the function into the placeholder via my general function. Is it possible to do this in MathCAD?
1 ACCEPTED SOLUTION
You need to pass a reference to the function without parameters, & add the appropriate parameters in the definition of the integral
Regards
Andy
2 REPLIES 2
Regards
Andy
Thank you Andy, very helpful.
