User Input Box
ptc-3805609
User Input Box
New to MC15 but getting along with the help of Google and this forum.
One question that I have yet to answer and would appreciate some basic help:
I want to be able to change a variable value via text box. However a text box formats entries as a string. I have researched it pretty extensively but with no joy.
Can anyone tell me how to easily get a text box to output a numeric value and not a string? I do not need to validate the info just have it spit out the numeric.
Much appreciated.
Chris
RichardJ
(To:ptc-3805609)
Inside the listbox script, use the VBscript CDbl() function.
Outputs(0).Value = CDbl(TextBox.Text)
RichardJ
(To:ptc-3805609)
Richard,
Thank you.
That worked. I also found that I could use "WebControls."
Thanks again.
Chris
The other way is to use the built-in function "str2num" (this function returns a constant formed by converting string into a number):
