Using CWD variable to reference worksheet
DaniBoy
Is it possible to use the CWD variable to reference worksheets? Meaning instead of clicking on the 'Include <<' button and choosing the referenced worksheet file, to write something like: "CWD\Reference.mcdx" in the field next to the Include << button. I'm using Mathcad Prime 6.0.
Thanks in advance.
LucMeekes
(To:DaniBoy)
If all you're trying to do is to include a (reference) worksheet in the same directory as where the (referencing) Mathcad worksheet itself is saved/located, then you can reference a reference worksheet named 'reference.mcdx' by '.\reference.mcdx'.
In (real) Mathcad, when specifying a reference worksheet you can tick an option to use a relative path, which has the same effect. I don't know if Prime has that option, I'm limited to Express.
Of course, if you are changing the CWD variable within your sheet, the above is not an option for you.
6 REPLIES 6
Use
concat(CWD,"Reference.mcdx")
Cheers
Terry
DaniBoy
(To:terryhendicott)
Nice try. Unfortuantely it looks like the include reference function does not accept ascii string. Also I found this other thread, saying that there is no solution for this issue:
https://community.ptc.com/t5/PTC-Mathcad/Insert-gt-Reference-using-a-Variable/m-p/353759
DaniBoy
(To:Fred_Kohlhepp)
Thanks for clarification, Fred. What I'm trying to do however is to  use the CWD variable in order to include another worksheet file. This would imply that I could, in some way or another, use this string variable (file) as a path to the referenced file. Which is not going to work, as you can see:
This method would work for readfile commands, the ones that read in data.  I think you're trying to include mathcad calculation files--the ones that are basically "copied" into the open file.  And you're right, that has never worked.
LucMeekes
(To:DaniBoy)
