Using a predefine function into a function
yfleury
Hi everyone,
I need to resolve a 1-variable equation into a function. For that, I want to use the function 'Trouver', which might be 'Find' in English, to resolve my equation.
The problem is that the function 'Trouver' is 'unknown' when I use it into my own function.
'Soit' means 'Suppose that'.
Does anyone as an idea of what's wrong in my function ?
TIA
LucMeekes
(To:yfleury)
Mathcad does not know the functions Trouver() or repartition(), nor the term or keyword Soit.
What is repartition() supposed to do?
It works like this:
That is to say: will find if the Mathcad built-in root can find it...
Thank you for your answer (again) Luc !
Repartition is a function that I coded, it calculate the cumulative density function of a pdf.
Also, Soit and Trouver are 2 french keyword that we can use like that :
It almost works now, just a few things to handle before everything is ok.
Thanks again Luc!
Yvan
LucMeekes
(To:yfleury)
Ah, I see. 'Soit' is in English the 'Given' statement that is used to start a so-called 'Solve-block'.
You cannot use 'Soit' (='Given') in a (user defined) function, but you can define the output of a solve-block to be a function.
Bonne chance!
I guess these few lines should do the job:
