Using slove function inside a program
WYL-disabled
Newbie
Can anybody kindly answer the following questions? I have some difficulty to make my program work. The program consists a defined function and a solve function inside a program.
1. Can I use Mathcad's solve function to solve a range of variable inside a program?
2. Can I use the local assignment operator (arrow pointed to the left) to define a function inside a program?
Your help in this subject is appreciated.
5 REPLIES 5
Can you please post a simple Mathcad file with examples you have in mind? That would help.
CollabAdmin
Hi-
Attached is my example file. The function outside the program works just fine, the one inside the program got an error message. Please let me know what went wrong.
Thank You Bonnie! You solved my problem. I got another problem which related to the answers I got from the solve function. It seems not giving me the right answer at sime point. Ant idea?
WYL
Regrets - I won't have time to look at this with the necessary care - but bear in mind that no numerical solver is perfect. There is sensitivity to the choice of initial seed, and also (as you pointed out) the problem that nonzero imaginary parts are entering some of your solutions. Play around with a constrained solve block, say, with lots of different initial seeds and tolerance criteria. There's no substitute for coming to know your equations really well!
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
