VB code in Push Button
Raiko
Hello all,
I ahve this irritating problem in VB code. I'm trying to add up to arrays of equal dimension via a push button control in MathCad (15 on Win 7) so that the output get's written only on demand to a file. But to no avail. Can't figure out what's wrong - see attached MC file.
Does anybody know enough of the BV in Mathcad to help?
Raiko
14 REPLIES 14
MikeArmstrong
(To:Raiko)
Which summation are you trying to achieve?
Mike
Hi Mike,
summation in the sense that I want to extend the array by the array I'm adding up. In the example I have a column array (vector) which I'd like to extend with another vector of equal size so that the result is a two-column vector.
Cheers
Raiko
MikeArmstrong
(To:Raiko)
Oh, so you mean like augment?
Mike
Correct!
MikeArmstrong
(To:Raiko)
I haven't seen that done before and not an expert on VB by any means.
If you don't mind me asking, what is the purpose of augmenting using a push button? Because I have few ideas to get around the issue.
Mike
Hello Mike
whenever I'm computing something and I do change a parameter I can see it with one set of parameters. Changing that changes the results, therfore I want to store the results in an intermediate file and only after I've changed some parameters and settings to add another set of data (i.e. on the click of a button). Later I'd retrieve the data for comparison.
I want to do it in VB as MC computes all the time and I can't control when it is stored in an external file.
Raiko
MikeArmstrong
(To:Raiko)
That's slightly different than what I had in mind.
I think you'll have to wait for one of the VB guru's to get involved. The only thing I could think of is passing multiple inputs and augmenting the data in a way it can be compared. But this is different from what you want.
Mike
Thank's a lot anyhow Mike
Cheers
Raiko
Fred_Kohlhepp
23-Emerald I
(To:Raiko)
I have a smilar problem, wanting to permute design values and save desireable results for use eslewhere.
Since I know almost nothing about VB, I've taken a different path:
Use a Mathcad file WRITE or APPEND command, but disable evaluation of the command. When I get a result I want to save, I enable the command (which modifies the file), then disable it again immediately. This isn't as elegant as a pushbutton, it requires two right-clicks and two clicks and an enter, but it works. And all that clicking will be good training for Prime!! 😉
Hello Fred,
that's the way I did until now. Tedious but it works. However, since I saw the push button from the "Extra Components" sheet (writing data to a certain file only on command) I wished I could collect data this way. Is that a MathCad pipe dream?
Raiko
Fred_Kohlhepp
23-Emerald I
(To:Raiko)
Raiko Milanovic wrote:
Hello Fred,
Raiko
I think it's a question for Mr. Jackson or Mr. Oakley!
I think it's posible, but I am really busy right now. I'll try to find some time to look at it soon.
http://communities.ptc.com/servlet/JiveServlet/showImage/38-1286-16192/applause.gif
Mike
Here are a couple of files provided by Collaboratory members.
