Vectors
Vectors
Does the changing the order of the vectors changes the angle of the resultant?I quite sure that the directions stays the same.
Vectors
The angle (direction) of the resultant vector remains the same. That's the beauty of the polygon method of vector addition...it doesn't matter what order the vectors are added.
Vectors
No. But make sure you use the same reference axis on the Cartesian coordinate system. You can state the angle in a positive counterclockwise direction from the positive x axis.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
