Vista
laraoz
Vista
Hi :
Have somebody load Mathcad 13 on a "vista" operating system? Could you please give a hint?
PhilipOakley
(To:laraoz)
Just had a reply from support which confirms that unfortunately vista won't run mathcad.
I think the support staff are between a rock and a hard place on this. Part of the problem is Microsoft!!
My colleague in support said:
"This is going to sound a bit curt, but unfortunately, Version 13 isn't supported on Windows Vista.
http://www.ptc.com/partners/hardware/current/support/mathcad13.htm
Let me know if there is anything else I can do for you."
Philip Oakley
[duplicate post]
See response to original post.
� � � � Tom Gutman
Try the following:
Install M13, right click on the icon and open properties, under properties click the compatibility tab, check xp compatibility and "run as administrator".
May work better.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
