What is the reason for this error in the answer?
dkothia
Newbie
Basically the answer should be a perfect zero (according to theory and also verified through hand calculation), so why this software is giving such high error.
Please tell me if I am doing something wrong as soon as possible.
6 REPLIES 6
Re: What is the reason for this error in the answer?
Because you are numerically evaluating the integral
The precision with which Mathcad calculates numerical evaluation is in the order of 10^-17.
You're doing nothing wrong. You could set the 'zero tolerance' of numerical calculation to a higher value (e.g. 10^-10) this would show all numbers x with |x|<10^-10 as 0. But it would obscure results that are actually meant to be e.g. 10^-12.
Then what is the solution to this problem, is there any other software with high tolerance value?
This is not a 'problem'. Just be aware that all calculations go with a certain uncertainty/accuracy.
Simply calculate 1/2-1/3-1/6 and see what comes out.Mathcad will tell you:
MsExcell will tell you 0, until you multiply the result with 10^18, then it spits out 27.76
If you want exact answers, use a symbolic engine (Mathcad, Maple, Mathematica, Maxima).
P.S. If you want to know why the 'error' is in the order of 10^-17, have a look at:
Numerical Precision in MathCAD
It's numerical evaluation precision error.  (10^-17 is a large error?)
Symbolic evaluation gives you zero:
Yaa..thank bro..drinks on me
Just change the result formatting from "General" to "Decimal":
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
