What's the difference?
SOLVED
Amethyst
Hi folks,
I fail to see the difference and also what crime I've comitted. Any clues?
Raiko
Tags (2)
Re: What's the difference?
Problem solved?
8 REPLIES 8
Can you upload a worksheet?
Here we go Mike
Problem solved?
Mike, help me please. How did you do that? I'm still without insight ?!
In the last line, J[n+2,k, k was not subscripted.
The problem is with the k when locally defining Y, k was not defined as a subscript.
When it should have been:
Oh dear it must be monday.
Thank you for spotting that Mike!
Raiko
No problem.
It certainly is Monday, although a good way through it .
Once again this problem highlighted Mathcad's useless error messages.
