In the PTC introduction video "PTC Mathcad in Action", it shows an example "Turbine Blade Design". The format of that document looks good and it shows how to use Mathcad feature in practice. Does PTC privides that example free and where can I find it?
Simon
In attachment you can find wworksheets for Mathcad 2001i and Mathcad Prime 3.0. And please check the following links "Fluid Mechanics with Naval Applications":
http://www.usna.edu/Users/mecheng/adams/indexf.html
Thanks.
Is there any worksheet for Mathcad Prime 2.0? I only have that version, the XMCD MCD convertor don't work on my computer.
That may be kind of a problem. You would need somebody who has installed Mathcad 15 and Prime 2, but not Prime 3 to be able to convert the MCD file to Prime2 format. Reason is that the installation of Prime 3 after Prime 2 kills the converter of Prime 2.
xmz s wrote:
... the XMCD MCD convertor don't work on my computer...
You need to install Mathcad 15 for that.
