Where is all legacy Mathcad stuff ( Electronic Books, Add-ons for Mathcad 8, 2000, 2001, 2001i) ?
SOLVED
Newbie
Where is all legacy Mathcad stuff ( Electronic Books, free Add-ons for Mathcad 8, 2000, 2001, 2001i) ?
Much of it was/is loadable even by newer and current Mathcad editions !
I did not find anything here, also Google does not find anything special if I look for "Mathcad Electronics Books".
Btw, I am still using Mathcad2001i - no software activation, enough math power -, for my own internal development purpuses. It runs well on W2k and WinXP.
If an employer or project owner asks me to do something with Mathcad, I expect a current version of course :-), thats the business.
With the newer Mathcad versions, it is still possible to save in the Mathcad 2001i format (but not in Mathcad 2001 format, or older ) :-).
Sincerely
Rolf
Re: Where is all legacy Mathcad stuff ( Electronic Books, Add-ons for Mathcad 8, 2000, 2001, 2001i) ?
33 REPLIES 33
With the newer Mathcad versions, it is still possible to save in the Mathcad 2001i format (but not in Mathcad 2001 format, or older ) 🙂
That is not quite correct. MC11 will save back to version 6. MC13 will save back to version 2001i. MC14 and 15 will save back to version 11 (I don't recall what MC12 could do, and can't be bothered to install it just to find out)
The final question is:
How to travel from the
http://communities.ptc.com/community/mathcad
to this menu level
http://www.ptc.com/appserver/mkt/products/resource/list-books.jsp?&rccg=888&nav=5279
, by what link or series of pages with links ?
So if I press "home" on
I get to
but how to get back ?
I am shure that not just me has a problem with that.
Thanks in advance.
Sincerely
Rolf
to this menu level
I don't think you can be honest.
I get to
There seems to be an error when you click 'home', which doesn't allow you to return to the previous page. To be honest I have tried clicking the 'home' link a couple of times and it only works sporadically. How about not pressing the home button, thus eliminating the need to press the back button
Mike
Sorry to say the question again, *** to the webmaster of PTC and the PTC moderatorrs ***
If I don´t use a deep link as I was told here,
how should customers go from the Matcad community main page
to the ressource page with the electronic books, and all the other links to the "Mathcad Resource Page" ?
There is some link "missing" AFAIK.
This is not an academic question, but a question how to use this website.
Indeed, I asked the question orignally, so that other users can "find" it.
Sincerely
Rolf
a)
Comment
If you call
you can access all other menu items
If you call
you see the SAME page, but you cannot access all other menu items, it looks as if there is no "real" contents if you click on it.
b)
Additionally, where is the Home URL of the "Mathcad LIbrary" ?
Smith Chart
http://www.ptc.com/appserver/wcms/standards/textoimgothumb.jsp?&im_dbkey=61423&icg_dbkey=888
says that it is part of the "Mathcad LIbrary",
but the given link is broken too.
http://www.ptc.com/resourcecenter/mathcad
[quote]
Access Forbidden
You might not have permission to view this directory or page using the credentials you supplied. It is also possible that your session has expired. In that case please close all of your browser windows and then try opening a new one. If you continue to have difficulties reaching a page you should have access to, please contact -.
[/quote]
Probably the file can be found at
Mathcad Resource Center: Mathcad Example Files
http://www.ptc.com/appserver/mkt/products/resource/list-dtav.jsp?&rccg=888&nav=5283
or do you expect to find it at another place ?
Ok I asked the webmaster about this, too, now...
Sincerely
Rolf
See the last post in this thread:
http://communities.ptc.com/message/151610#32554
(which does not answer your question, it just reinforces your point).
Richard, MC12 saves back to Mathcad 2001 -- I just checked.
I seldom use my copy of MC12, since MC13 seemed to be much more stable when it came out. And I continued to rely on MC13, even after MC14 came out, because MC14's print preview crash really ticked me off. I only started using MC14 when the M020 release came out and fixed the print preview crash.
Actually, the only reason I keep MC12 around now is to be able to compare its features with those of its predecessors and successors, as you are doing now.
I use MC11, for some legacy worksheets that will not work in later versions (due to SUC, the demise of the Numerical Recipes Function Pack, and a couple of other changes that occurred going to 12), and for the Maple symbolic engine. I use MC13 only for the Maple symbolic engine when the results are too large to display in MC11, and for testing/comparison. I use MC15 (and prior to that MC14) for everything else. The only thing I would ever use MC12 or was testing/comparison, so last time I went through the long and tedious process of installing all the Mathcad versions I couldn't be bothered with 12
