Which version of Mathcad comes with Creo Parametric 3?
David_M
The installer, links and title say Mathcad Prime, but the "about" page says Mathcad Express, both version 3.1.
I read that if you buy Mathcad Prime you can also use Mathcad 15. Does this apply to the version bundled with Creo Parametric 3? I'm guessing not.
Cheers
RichardJ
(To:David_M)
Mathcad Prime and Express are the same installer, which is probably the source of the confusion. Express is what you get if you don't have a license for Mathcad. Since PTC does not seem inclined to ever give anything away for free, my guess is that you have Express. If you have a license for Prime it will also work for Mathcad 15, but as I said, my guess is that you don't. You can tell for sure by starting Mathcad. If you have Express, it says so at the top of the screen.
RichardJ
(To:David_M)
