Wireless Power Transfer Re-visited with Mathcad Prime 2.0
aallawi
The power of Mathcad in solving complicated design problems is very well known. This worksheet will show the design of a coaxial gapped core fed from a central straight conductor. The primary current is 500 A. and the power transferred is 50 KW. This can be used to charge battery vehicles and could find other applications as well.
I did my first WPT since 40 years ago using high power valve oscillator but this one is based on inductive coupled coils.
I hopw you will enjoy reading it.
Kind regards to all of you.
2 REPLIES 2
vlehner
(To:aallawi)
Hi Ahmad,
MathCad can be indeed a powerful instrument.
We can find an exact solution for the coil diameter.
A tipp for you:A symbolic evaluation here is better for calculating the resistance R2 as following:
Unfortunately i can't attach the files here.
Best regards and Welcome here,
Volker
ps.: I'm working with MP4.0
have fun!
Volker
aallawi
(To:aallawi)
Thanks very much indeed Sir. I will take this note.
Regards
A.Allawi
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
