Won't show very small numbers
ptc-4254605
I am working with these things called solubility product constants. They entail working with numbers like 10^-53.
The problem is my version of MathCad (MathCad 14) displays numbers less than some magic number as 0.
And I really need to see the number in exponential notation, no matter how small. If possible.
I went banging around in the manual to find some way to change the default smallest number and came up empty.
I have attached a file as a MathCad 12 .mcd file that illustrates the problem.
Jeff Corkern
Consider the following as a statement of logic, and rank it as "True" or "False":
"If people possess immortal souls, it should be possible to logically deduce this by objective analysis of their actions."
http://www.theninepointfivetheses.blogspot.com
Change the 0 threshold:
click in an empty space, then Format>Result, select the 0 tolerance tab and change to, say, 307.
Could also define a unit like u=10^-20.
