Work
vivian-disabled
Work
I have two problems I need help with!
14.[1pt]
Which of the following statements is true? / I do it but it's still wrong, so I would appreciate it if anyone can explain why?
A) The work done to raise a box onto a platform depends on how fast it is raised. /FALSE/
B) The kinetic energy can be positive or negative. /FALSE/
C) The kinetic energy depends on the reference frame of the observer. /TRUE /
D) The kinetic energy of an object is independent on the direction of the motion involved. /FALSE?/
E) If the Earth revolves around the sun in a perfectly circular orbit, then the sun does work on the Earth. /TRUE /
F) Spring A and B are identical except that A is stiffer than B; that is kA > kB. More work must be expended on spring A if both springs are stretched by the same amount. /TRUE /
15.[1pt]
With brakes fully applied, a 1560 kg car deccelerates from a speed of 83.0 km/hr. (a) What is the work done by the braking force in bringing the car to a stop? (b) What is the change in the kinetic energy of the car?
Known: initial velocity = 83.0 km/hr = 23.055 s/m
mass = 1560 kg
unknown: Work done by braking force & change in kinetic
KE = mv^2/2
KE final= 0 J since the final velocity = 0m/s when the ball is at the highest height.
KE initial = mv^2/2 = 1560 kg x 23.05 s/m ^2 / 2 = 414595.75 J
W done by brake = KE final - KE initial
thus W = 0 J - 414595.75 J = -41595.75 J
and the change in kinetic energy is 41595.75 J since the final is 0 ???
And the computer gives back that the answer is wrong, so what did I do wrong?
>help with!
>14.[1pt]
>can explain why?
>observer. /TRUE /
>involved. /FALSE?/
>amount. /TRUE /
E is false; if there is no change in gravity altitude, there is no work done
>15.[1pt]
>of the car?
>km/hr = 23.055 s/m
>mass = 1560 kg
>KE = mv^2/2
>J
>KE initial
>-41595.75 J
>final is 0 ???
Perhaps you have the signs backwards, since the change in kinetic energy of the car must be negative, since it had positive energy.
TTFN,
Eden
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
