a name is required here
SOLVED
Highlighted
Contributor
help please...
1 ACCEPTED SOLUTION
15 REPLIES 15
Re: a name is required here
You should NOT use global assignments ( = ), but boolean equality to define the equations in your solve block. Type [CTRL =] to get those. They show as a bold equals sign ( = ).
Tags (1)
Additional remarks:
1) You have to only use the function names without the argument parenthesis (use "C" and not "C(t)")
2) You have only 5 equations but 6 functions to solve for.
Thank you, can you attached file please?
and why is f(t):0.5*cosh(t)??
you should provide the f (t); what I chose is a convenience function. I do not believe that Mathcad is able to determine f (t) as an unknown knowing only its initial condition.
thank you
but the answer is below the attached file.
Do you know why?
please..
If there were a further differential equation in f(t), things would change. See the following example:
