a name is required here
JPark61
8-Gravel
help please...
1 ACCEPTED SOLUTION
LucMeekes
(To:JPark61)
15 REPLIES 15
LucMeekes
(To:JPark61)
You should NOT use global assignments ( = ), but boolean equality to define the equations in your solve block. Type [CTRL =] to get those. They show as a bold equals sign ( = ).
Additional remarks:
1) You have to only use the function names without the argument parenthesis (use "C" and not "C(t)")
2) You have only 5 equations but 6 functions to solve for.
I attached new pic.
can you solve it please..
-MFra-
(To:JPark61)
JPark61
8-Gravel
(To:-MFra-)
Thank you, can you attached file please?
JPark61
8-Gravel
(To:-MFra-)
and why is f(t):0.5*cosh(t)??
-MFra-
(To:JPark61)
you should provide the f (t); what I chose is a convenience function. I do not believe that Mathcad is able to determine f (t) as an unknown knowing only its initial condition.
JPark61
8-Gravel
(To:-MFra-)
thank you
but the answer is below the attached file.
Do you know why?
please..
-MFra-
(To:JPark61)
If there were a further differential equation in f(t), things would change. See the following example:
JPark61
8-Gravel
(To:-MFra-)
can you send me a file?
-MFra-
(To:JPark61)
I've attached the file.
LucMeekes
(To:JPark61)
That very blurry picture shows a graph with only 4 traces. That's 4 functions, not 6.
Are you sure you have entered the complete set of ODE's, required for solving the 6 functions that you are trying to find?
I attached new pic.
LucMeekes
(To:JPark61)
