calculations end with incorrect results
SOLVED
Highlighted
Regular Member
Not sure why the results at the end are incorrect.  There do not appear to be any mathcad errors.  Any help would be appreciated.
1 ACCEPTED SOLUTION
Highlighted
Re: calculations end with incorrect results
You have to use vectorization in the last calculation:
2 REPLIES 2
Highlighted
Highlighted
Dear Werner,
Thank you very much!
