conductor
conductor
When the voltage across a certain conductor is doubled, the current is observed to increase by a factor of three. What can you conclude about the conductor?
I have no idea. Please help
conductor
>the conductor?
Surely, you've covered normal conductors by this time? What's the definition of a conductor's resistance? Did it change when you changed the voltage?
TTFN,
Eden
conductor
>the conductor?
This is a non Ohmic conductor. V = IR does not hold. It could be a forward biased diode or a giant magnetoresistance material or a small gap semiconductor. It is not metallic.
Physics: Common Sense made Obscure by Mathematics Don Sparlin
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
