cut and paste into wordperfect
Newbie
I tried the following:
1) created a vector A of 3 elements long filled with 1,2 and 3
2) created a variable B by naking a copy of A (i.e. B:=A)
3) created an X-Y plot using A and B as the Y and X axis parameters, nice 45 degree line appeared in my plot.
4) selected graph, the chose copy from the edit menu
5) opened wordperfect, then from the edit menu chose paste.
Problem: The result was is you only get frame of the graph with no data, legends, axis labels or anything. Upon further review this bug has existed in mathcad 7,8,9 and now 2000. Is this going to be fixed, is there a good work around? I also noticed other users having the same problem with microsoft word.
TIA Marco
Use Paste Special from the Edit Menu instead of paste. This pastes the graphic as a bitmap, which is not linkable. It's not a perfect solution, but it's fine for most of your presentation needs.
