defining a variable
jreddy
defining a variable
hello im solving the equation at the end .But i dont want that unknown variable to be marked in red colour how to solve this problem.
36 REPLIES 36
here T_2_10k is taking the value of 1ft*lbf...how could mike solve with out getting this error
24-Ruby V
(To:jreddy)
Can't debug a picture.
Also I already had written twice in this thread what to do to make the symbolics happy (=make the solved for variable unknown to the symbolics).
see this file
24-Ruby V
(To:jreddy)
jagadeesh reddy wrote:
see this file
Yes, I experience the same problem. Curiosly enough it works if you define T_2_10k to 1 Joule instead.
But I wouldn't recommend that mixed symbolic/numeric approach anyway.
Can you mention the clear process for symbolics it into symbolics for me
Thank you
24-Ruby V
(To:jreddy)
Thank you
Already done here
http://communities.ptc.com/message/265124#265124
and here
http://communities.ptc.com/message/265234#265234
So one last time: Immedeatly after defining T_2_10k you follow the definiton with T_2_10k:=T_2_10k.
This should work.
Thank you this worked
