dll reuse in prime 7
KC_9978072
Hi, before i build some .dll files and work well in mathcad 15. I install mathcad prime 7 and try to reuse these .dll files, but cannot load dll function. These dll files are put in the folder "C:\Program Files\PTC\Mathcad Prime 7.0.0.0\Custom Functions". Or should i put them to another folder or something i should do previously?
1 ACCEPTED SOLUTION
LucMeekes
23-Emerald I
(To:KC_9978072)
Mathcad 15 is a 32-bit application, Prime 7 is a 64-bit application. I would not be surprised if all it takes is to recompile the source of your dll's to a 64-bit dll.
2 REPLIES 2
LucMeekes
23-Emerald I
(To:KC_9978072)
KC_9978072
(To:LucMeekes)
thanks Luc. Actually, i lost the source code and hardly to recompile to 64-bits dll. So i just can reuse these old dll files. have you any suggestion to load 32 bit old dll files to prime 7? or just to use mathcad 15?
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
