express and prime comparation
dbayasgalan
could you tell me mathcad prime and express comparation?
6 REPLIES 6
RichardJ
(To:dbayasgalan)
Does IF statements count as programming?  or does it mean pure C++ or VB codes?
There is an "if" in the programming menu that almost certainly won't  work in express.
There is also an If function, very similar to the one in EXCEL:   if(test, return if true, return if false)
That one might squeak past.
LucMeekes
(To:Fred_Kohlhepp)
It does.
if( , , ) works in Express.
It means everything shown in the "programming" menu:
As noted by others, there is a seperate "if" function that is available in Express (under "functions", not "Math->Programming").
