filtering repetitive values
SOLVED
rcallisaya
Marble
Hi:
I would like to filter the repetitive values of the vector [t]  to form the vector [q].
The file in mathcad 15 is attached.
1 ACCEPTED SOLUTION
Re: filtering repetitive values
4 REPLIES 4
I'm using Prime Express, cannot program.  But you can still get there:
Prime 4.0 file attached
I really appreciate the solution,
Thanks.
I really appreciate the solution LucMeekes
Thanks.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
