help on equivalent resistance
I understand how to find equivalent resistance, but I'm having so much trouble with this problem; I couldn't get the right answer even though I spend hours to do this problem, please help me.
The picture to the problem is the attachment
Find the equivalent resistance of the circuit shown in the attachment.
abk511
>the attachment
>attachment.
>Thanks,
>abk511
The two pairs of resistors
4 ohm + 2 ohm and 6 ohm + 3 ohm should be combined into 6 ohm and 9 ohm respectively. This gives you two "delta" networks.
You'll need to convert one of the deltas into a "wye" configuration. This can be done by considering the equivalent resistance across each pair of connections in the delta with the 3rd connection disconnected and equating that with the equivalent two resistance in the wye network. It's fairly straight-forward. If you run into difficultly, this link shows the correct answer:
http://www.ece.pdx.edu/~ece2xx/ECE221/Lectures/ResistiveCircuitsx4.pdf
Once that's done, your left with a parallel circuit of series resistances.
TTFN,
Eden
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
