help on using symbolic solve and vectors with units
ptc-4650249
I'm trying to use a the symbolic solve function to rearrange an equation and solve for a variable, but I'm having trouble because the answer is a vector with units.
Example: given the area of a circle, find the radius. I enter:
A:= 3.14 cm^2
(A = pi * r^2) solve,r->
and it spits out a column vector (displayed here as a row vector)... -> (1cm, -1cm)
and I want to set that to another variable, say, R1, so I now have:
A:= 3.14 cm^2
R1:= [ (A = pi * r^2) solve,r-> (1cm, -1cm) ]
R1= (1cm, -1cm)
I know it can only be the positive value, so I want to pull that value out:
R2:= R1[0
this gives me an error: R1 is red and the hover text reads "this value must be an array"
How can I set a variable to be the positive radius? (R= 1cm)
(I know I could just rearrange the equation here for the radius in the first place, but I want to keep it clear where I got the equation from. Also, this is just a simple example and I'd want to do it with something more complicated and want to avoid an algebra mistake)
Thank you very much!
Eli
(using Mathcad, version 14.0.0.163 [build 701291152] on windows7, 64bit)
RichardJ
(To:ptc-4650249)
There's a couple of approaches
RichardJ
(To:ptc-4650249)
Hi Richard,
thank you so much for your response. That is exactly what I was looking for BUT...
when I try the same thing you're doing, whether in the same document with different variables or in a new document, I still get an error. This time it's saying that my radius variable is undefined (with both methods).
I think I must be entering it wrong, although it looks the same as yours (from what I can see).
Any thoughts on what I'm doing differently? My file is attached.
thanks!
Eli
RichardJ
(To:ptc-4650249)
It should work. Try downloading and installing the latest available service release for version 14.
VladimirN
(To:ptc-4650249)
Please check the attached Mathcad document below.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
