Hi i know this is really basic ,im starting to learn how to use Mathcad 15.
Im trying to replicate a pdf document that used Mathcad , but i cant plot the graph of the signal i pointed , its the Fourier transform of an entry signal.
What should i put on Y axis and X axis? , im pretty sure the document used only what is on this Mathcad file.
"help_mathcad15" is the Mathcad file and "Graph" is an image of what im supposed to get.
please help a newb :s
Yes , thank you very much 🙂
its embarrasing...i thought i tried that but i used a determinant instead of absolute value
*Facepalm*
