help syntax
SOLVED
Amethyst
Re: help syntax
You are trying to assign a value to 0 (the third element in the vector to the left of the assignment ':='). That is not allowed. 0 should remain 0 ...
If you change that 0 to epsilon_sub_3 for example, it should work.
Re: help syntax
Re: help syntax
I know......Thanks!
