help syntax
kenan2
help syntax
why can I not solve this ?
LucMeekes
(To:kenan2)
You are trying to assign a value to 0 (the third element in the vector to the left of the assignment ':='). That is not allowed. 0 should remain 0 ...
If you change that 0 to epsilon_sub_3 for example, it should work.
LucMeekes
(To:kenan2)
kenan2
(To:LucMeekes)
I know......Thanks!
