how to get a program run just only when the worksheet is opened
JefferyGu
Hi Friends,
Is there anybody knows that how to get a program run just only when the worksheet is opened?
There are some codes in the TextBox control in the test.xmcd file. When I press Ctrl+F9 button, all the code will be executed again. In fact, I just want them to be executed when I open the worksheet, and then do not let them run even when I press the Ctrl+F9 button.
As we know, this function is easy to realized in Excel. Can it be implemented in Mathcad?
Thanks and Best Regards.
Jeffery
StuartBruff
(To:JefferyGu)
Jeffery Gu wrote:
Hi Friends,
Jeffery
Try the attached. It has some code to detect first time of running and then avoids running the 'start' code if it's already happened.
Stuart
StuartBruff
(To:JefferyGu)
Jeffery Gu wrote:
Hi Friends,
Jeffery
Stuart
Hi Stuart,
Thanks very much.
Jeffery
StuartBruff
(To:JefferyGu)
Jeffery Gu wrote:
Hi Stuart,
Thanks very much.
Jeffery
No worries, Jeffery.
