inseert function broken
LarryBaxter
Participant
My faithful MCAD14 no longer inserts functions. Insert|function does not open the function menu. Old MCAD files are also broken.
Tags (1)
Re: inseert function broken
All of a sudden (yesterday it still worked and now it doesn't anymore) or did you not use it recently and it may have happened somewhere in the course of time?
What's your Operating System? Was it recently updated?
Can you still use it as a simple calculator?
What if you type a function's name?  Try  sin(1)=
OS: Win 10, not recently updated
Still usable as calculator
"sin(1)" typed works
And what about the time period between: it (still) worked and 'now'?
Mathcad 15 still work on Windows 10, but the general recommendation is to upgrade to Mathcad Prime 7.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
