limiting an optimization vector result to positive entries
DanJoffe
1-Newbie
Is there a way to convince mathcad optimizer that your really serious when you want all the entries of an optimization vector to be positive?
1 ACCEPTED SOLUTION
RichardJ
(To:DanJoffe)
minerr treats constraints as soft constraints, and minimizes the error in them along with all other errors. If you want to make them hard constraints you need to weight them very heavily. Use v*10^15>0.
2 REPLIES 2
RichardJ
(To:DanJoffe)
Richard,
Thanks...I had encouraged it with 10^6 before I posted the question. It obviously wasn't enough encouragement.
Your suggestion of 10^15 worked great!
Thanks...
Dan
