msxml6.dll is either not designed to run in windows or it contains an error
areddy
3-Visitor
msxml6.dll is either not designed to run in windows or it contains an error.
what does this error mean, how can it be resolved ???
4 REPLIES 4
LucMeekes
(To:areddy)
I guess a little more information is in order.
Who's complaining?
Why do you need Msxml6?
Where did you get the dll from?
What is your OS? Is it 32 or 64 bit?
i am trying to install mathcad on 64 bit machine for a client in houston. while installing the software he is getting the above mentioned error.
Amarnath
LucMeekes
(To:areddy)
Mathcad or Prime?
Did you check bitness?
Was an incorrect Msxml6 existent on the computer?
VladimirN
24-Ruby II
(To:areddy)
What version of Mathcad are you trying to install? And Windows OS?
