QUESTION: If you are asked to find the area of a triangle and use logarithms.how could you use logarithms to find the area , if these are oblique triangles ?Please list for all of the following conditions.all of these are known factors1. 2 angles & a side of a triangle2. 2 sides & the included angle 3. 3 sides of a triangleI would like to think that I could just convert an area formula into logarithm form.Only problem is, I'm not 100% for sure if this is correct.FOR EXAMPLE: Let's say we need to find the area of a right triangle .formula : A=1/2*base*heightIn log form may be changed to ?? logA= log1-log2+log base+log heightIf not please show how this should be.Then for 1. formula : K= c^2*(sinA)*(sinB)/2*(sinC)can be changed to ?? logK=log(a+b)+log(a+b)+log sin A+log sin Blog2+log sin C K=a^2*(sinB)*(sinC)/2*(sinA)logK=log(c+b)+log(c-b)+log sinB+log sinC-log2+log sinAthen for 2.K=b*c*(sinA)/2 can be changed to ?? logK=log b+log c+log sinA-log 2K=a*b*(sinC)/2 can be changed to ?? logK=log a+log b+log sinC-log 2then for 3. K=the radical sign over s(s-a)*(s-b)*(s-c)How can I use Heron's formula with logarithms when it contains a radical sign?All hints & pointers are greatly appreciated. Thanks! :-)
