not able to solve a second order ordinary differential equation
madhukwd77
3-Visitor
 I am trying to solve a second order ordinary differential equation.
I had attached mcdx file for reference.
It says " This Value must be a function".
Please suggest the solution if possible.
my final requirement to plot the x(t), x'(t) & x''(t)
6 REPLIES 6
Thanks a lot ValeryOchkov for quick solution of my problem.
You welcome!
I do marks "solved" and "kudo" Smiley Winkin same cases!
LucMeekes
(To:madhukwd77)
There are other ways:
Attached is a Prime 5 file with a plot of this solution.
LucMeekes
(To:ValeryOchkov)
Like this...Valery?
Or did you want to see the quick method:
