otherwise statement
idahoan
11-Garnet
otherwise statement
i am sure the answer is obvious, but at the moment i am not seeing it.  how do add the "otherwise" statement or function?  i have read that you have to click on the function button and not just type the word.  but i do not seem to be able to find the required button.
1 ACCEPTED SOLUTION
"otherwise" is used in PTC Mathcad 15 and below.
"else" etc is used in PTC Prime.  "else" is found on ribbon at Math | Operators and Symbols | If Programming.
Cheers
Terry
2 REPLIES 2
Cheers
Terry
In Prime they have implemented a very convenient feature: You may type "else" or any other programming statement and if you follow it by pressing Ctrl-J, the text is converted to the appropriate programming statement.
I don't like Prime but this feature is highly appreciated!
