plot graph from table or from excel in Mathcad
zaki_rhm
6-Contributor
how to plot graph from table or from excel in Mathcad ?
13 REPLIES 13
You cannot use a table to stack matrices you use the "stack" function.
Cheers
Terry
I want him like that in this file excel.
i cha,ged pre with vol but i found th problem in the picture. how to remove the line and the area indicated in the
Graph as requested
With Mathcad Prime doing the calculations that are done in excel
thank you very much sir.
I am currently working on MATHCAD 15. It applied the same steps, but the following message appears:
this value must be real, how to set it, ( attached file ).
The reason for the error is that pre is a nested matrix. Its element #14 is not a scalar but a 15x1vector.
The reason for this is that p is nested, its element #2 is a 15x1 vector
The reason for this is that epsilon is nested, its element #2 is a 15x1 vector
Haven't traced any further back.
This was subtle.
in your sheet epsilon[2 set the element 2 of epsilon to a 15,1 matrix
in attached sheet I have got around this and given more points on the curves.
thank you sir,
How can I calculate the are of the diagram ?
Like This
I am not sure how the equation for area handles the bottom of the diagram.
You still need to set the real volumes not the numbers 1 to 17
Cheers
Find short example attached
