problem with unit=0.0 when solve quadratic equation
SOLVED
Atomique13
2-Guest
I am new to Mathcad,I have been using PTC Mathcad Prime 5 since yesterday.
I have a problem when I use solve and assume for this quadratic equation. All the variables have mm as unit. If I assume mm <> 0 then it works. The answer I am looking for is 233.41847464108950079 mm.
Ps. If I put = it shows the good answer (my bad, I was too frustrated about the if and else thing to try), but why does it show if and else?
Thank you
1 ACCEPTED SOLUTION
For numerical result (especially with units) you may consider using a numeric solve block instead of the symbolic solver:
2 REPLIES 2
LucMeekes
23-Emerald I
(To:Atomique13)
The symbolic processor in Mathcad (and Prime) does not know about units, it treats them as unknown variables.
You can write sol to be a function of Lp, Dp1 and Dp2, so instead of sol:=... you write sol(Lp,Dp1,Dp2):=...
Then you can evaluate sol(Lp,Dp1,Dp2)=
to get the answer.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
