problems with the conditional operator
SOLVED
Topaz I
Hello everyone,
why the program, reported below, does not work? There seem to be problems with conditional operators. In fact the program on the right, where no conditional operators appear, gives the required result.
I sincerely thank those who will find the error and all those who will try to solve it.
Attached is the worksheet.
1 ACCEPTED SOLUTION
Re: problems with the conditional operator
Hello everyone!
I solved the problem this way:
13 REPLIES 13
The if() function and the if construct don't always work symbolically. The step function 'Phi()' may be a symbolic alternative:
Highlighted
In this case, using the unit step is a real nonsense!
You want something to work.... or not?
Incidentally, those simple theta's at the end of many of your if-blocks do not actually do something.
It's the final theta, at the end of the program that produces the result.
If you want your program to produce the result of the first if statement that is TRUE, you can use:
return theta
Where return is the programming construct, from the programming panel...
... but it still doesn't work .....
Sorry, I didn't want to suggest that changing it would solve your problem.
The evaluation of the same logical equation in the comparisons takes on opposite values as seen in the photo, so nothing works.
{Ah, picture cut & paste is back!}
Francesco, guarda qui:
Successo!
Luc,
thank you for the time and work dedicated to me, but your answer gives a different result from the one I expected and that you know what it is.
